LostInTokyos
Jan 20, 2025Aspirant
NAS RN104 with "gone" Snapshot is still using space. Software realese is 6.10.10
As from the title and th picture, i still have the snapshot problem error. I delete alot of snapshot and disabled the feature, but even using SSH, typing the command i saw in a couple of other p...
LostInTokyos
Jan 21, 2025Aspirant
Thnak You Stephen, i've already done it twice, but nothing changed.
I guess it's the same situation of orphanaged snapshot coming from a software update.
And it's strange that trying to use SSH Terminal seams like i just "talking to ghosts" as the commands i type, doesn't sort anykind of effects on the NAS.
Jan 21, 2025Guru - Experienced User
What firmware are you running? The command you are using was only for snapshots from 6.1.x firmware, so not relevant for anything current.
Post 2 here gives the command to delete a specific snapshot from ssh:
You could also
- back up all the files
- do a factory reset
- rebuild the NAS
- restore the files from the backup
