nextwavepc's avatar
May 10, 2019
hidden snapshots wont delete
i am showing 1.36TB of snapshots - i only had them enabled on a directory with 200mb shared. i have tried to delete using the ssh to upgrade the snapshot - but no dice. i am running current firmware of 6.10
ive tried, https://notes.ponderworthy.com/upgrade-snapshots-in-a-readynas
and https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/How-can-I-delete-invisible-snapshots/td-p/1352107
i can make new and delete just fine. but i am unable to see the "hidden snapshots" am i missing something?
  • StephenB's avatar
    Do you see the snapshots (via ssh) when you enter
    # btrfs subvolume list /data
    (use your actual volume name instead of /data if you are using flexraid)
    If you can see them, then you could try manually deleting them with
    # btrfs subvolume delete /path
    using the full path of the snapshot (something like /data/sharename/.snapshots/xx/snapshot).  Make sure you include the volume name - the btrfs list command doesn't include it.
    If the deletion works, you likely will need to do a balance (and maybe a scrub after that) to reclaim the space.
    • nextwavepc's avatar
      nextwavepc
      Guide
      this is what i get when i attempt that command
      Using username "root".
      [email protected]'s password:
      Welcome to ReadyNASOS 6.10.0
      Last login: Fri May 10 10:09:25 2019 from tech-1
      root@NWNAS:~# btrfs subvolume list /data
      ERROR: not a btrfs filesystem: /data
      ERROR: can't access '/data'
      root@NWNAS:~# root@NWNAS:~# btrfs subvolume list /data
      -bash: root@NWNAS:~#: command not found
      root@NWNAS:~# ERROR: not a btrfs filesystem: /data
      -bash: ERROR:: command not found
      root@NWNAS:~# ERROR: can't access '/data'
      • StephenB's avatar
        What is the name of your data volume (look on the volume tab of the web ui)?
ProSupport for Business
