Tommrock
Sep 01, 2023Aspirant
NAS RNDU2120, how LED status on boot.
Hi there, anybody who knows where to get information about LED pattern on the front panel after boot and various test. How do I read the pattern?
Sep 01, 2023Guru - Experienced User
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configurationTommrock
Thanks Stephen,
Couldn't find that appropiate info in my docs.
Could you maybe give me a hint how to fix another NAS problem for Win11: "ERR_SSL_VERSION_OR_CIPHER_MISMATCH" I had the NAS working nicely on my old Win7 for many years but after migration to 11 it seem to fail.
Further, I could reset the NAS to factory status and logging on using the Url ip. I managed to change the PW and that worked OK. But, the RAIDar scanner can not detect any NAS in my network.
Are these problems connected to eachother.
Many thanks for any suggestions.
Best regards
Tommrock
- StephenBSep 01, 2023Guru - Experienced User
It's not about Windows, it's about the browsers. You are running 4.2.x firmware in the NAS, which doesn't support TLS 1.2. Current browsers require that version of TLS.
For now, you can gain access with Edge in IE mode, or by using Firefox and manually setting security.tls.version.min to 1. Do that by first browsing to about:config and then search for the setting.
Longer term, there are two options.
- convert your NAS to OS 6 firmware
- install an add-on which adds TLS 1.2 support.
The add-on is here:
If you want advice on converting to OS-6, let us know.
