Tommrock
Sep 01, 2023Aspirant
NAS RNDU2120, how LED status on boot.
Hi there, anybody who knows where to get information about LED pattern on the front panel after boot and various test. How do I read the pattern?
Sep 01, 2023Guru - Experienced User
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configurationTommrock
Sep 12, 2023Aspirant
Hi again Stephen,
Thanks for your support but I am getting stuck - again.
This is what the glitch. Quick revenue of my attempts.
1. Using a wired Ethernet connection.
2. Still getting the error message of a non supported network protocol
3. Raidar 6.5 does not connect.
4. Raidar 4.3.8 does connect, see attached pics
5. The HDD came up and i could initilaze it.
6. Here i'm struck.
7. I can not enter the SETUP page, see attached pic
8. Just telling me that there are no shares.
Hopefully this can give you further picture of my problem, how to proceed.
Do you think it still is a network problem or a drive problem?
I intended to do an USB NAS OS update but i couldnt find the proper HW image file. I had to cancel that idea.
Is there still any hope for this "out of date" drive, should it belong to the recycling bin?
Many thanks,
Tommrock
- StephenBSep 12, 2023Guru - Experienced User
The last screenshot isn't getting you into frontview, that page is giving you access to shares that have http/https enabled. Since you don't have any, the list is empty.
Try https://192.168.1.175/admin again. If you saved the admin password in the browser, be careful to use the default netgear1.
- TommrockSep 12, 2023Aspirant
Hi Stephen and thanks for your reply.
I think you are to far ahead because - I get stuck earlier i the personializing scheme.
I am trying to explain in cronological order what is happening. I cannot SETUP my devise!, see pic.
Best regards
Tommrock
Try browsing to https://192.168.1.127/admin using Edge in IE mode.
If that fails with the same error, then download firefox, and then browse to about:config in firefox. Search for security.tls.version.min and then set it to 1. Then browse to https://192.168.1.127/admin in FireFox.
After setup, you can install an add-on that would give you the TLS support you need to eliminate the SSL version mismatch. Another (IMO better) option is to convert the Ultra to run OS-6. That would start with upgrading the memory to at least 2 GB (which is inexpensive and not difficult to do).
Hi again,
I trtried your suggestion, but unfortunately no luck. See my screenshot.
I modified the security key from 3 to 1.
After that I was browsing to my drive.
The screenshot tells you the technical issues.
Is there any welldocumented procedure to maintain an OSX version upgrade using the USB-port.
Best regards,
Tommrock
Again, you aren't including the /admin suffix in the URL, so you are ending up at https://nas-ip-address/shares (and not frontview - which is https://nas-ip-address/admin).
Even after the change to the TLS security you will still need to click through a security warning.
Tommrock wrote:.Is there any welldocumented procedure to maintain an OSX version upgrade using the USB-port.
The conversion to OS-6 isn't done through the USB port, so you do need to get into Frontview first.
