arhlene
Jan 12, 2017Aspirant
NAS102 Power light flashing, can't access unit through ReadyCloud
Hi, yesterday my NAS was off (possible power outage?) so I powered it back up but it was not visible on the network and the blue power light was/is flashing (1 short, 1 long). I could not access it ...
Jan 13, 2017Guru - Experienced User
arhlene wrote:
I took the drives out, tried to reinstall the OS but I'm not sure if that worked
It can't work, because the function reinstalls the OS onto the drives.
arhlene wrote:
I reinstalled one of the drives but that did not work. I swapped it out with the second drive and am able to access it from my PC
That suggests a problem with the first drive. After the backup completes you might want to test it with seatools in a PC.
arhlene wrote:
but the power light is still flashing and ReadyCloud access is still unavailable.
Can you reach the web admin page (either use https://nas-ip-address/admin, or get there via RAIDar). It might also be useful to download the log zip file.
arhlene
Jan 13, 2017Aspirant
Disregard, I found it. So, how do I attach a log zip file?
- mdgm-ntgrJan 13, 2017NETGEAR Employee Retired
You don't. You email the zip file in (see the Sending Logs link in my sig).
- arhleneJan 14, 2017Aspirant
Ok, I emailed the log file a few hours ago.
- Retired_MemberJan 14, 2017
There was only one HDD in the chassis when you downloaded the logs, and it doesn't seems too happy:
Model: ST3000VN000-1H4167
Serial: ******2B
[Tue Jan 10 16:41:13 2017] ata3: SATA link down (SStatus 0 SControl F300) [Tue Jan 10 16:41:13 2017] ata2: SATA link down (SStatus 0 SControl 300) [Tue Jan 10 16:41:13 2017] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [Tue Jan 10 16:41:13 2017] ata1.00: ATA-9: ST3000VN000-1H4167, SC43, max UDMA/133 [Tue Jan 10 16:41:13 2017] ata1.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [Tue Jan 10 16:41:13 2017] ata1.00: configured for UDMA/133 Jan 10 15:45:04 NAS102 kernel: res 51/04:02:02:00:00/00:00:00:00:00/e0 Emask 0x1 (device error) Jan 10 15:45:04 NAS102 kernel: ata1.00: status: { DRDY ERR } Jan 10 15:45:04 NAS102 kernel: ata1.00: error: { ABRT } Jan 10 15:45:04 NAS102 kernel: ata1.00: configured for UDMA/133 (device error ignored) Jan 10 15:45:04 NAS102 kernel: ata1: EH complete Jan 10 15:45:04 NAS102 kernel: ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 Jan 10 15:45:04 NAS102 kernel: ata1.00: irq_stat 0x40000001 Jan 10 15:45:04 NAS102 kernel: ata1.00: failed command: READ DMA Jan 10 15:45:04 NAS102 kernel: ata1.00: cmd c8/00:04:04:00:00/00:00:00:00:00/e0 tag 9 dma 2048 in [repeated numerous times]So I'd start with that.
You should test this HDD with the manufacturer's tool.
