ndalby
Jul 17, 2014Aspirant
NasDuo v2 Secure Erase
HI All, Bit of weird one this (at least to me). I'm getting ready to sell my NasDuo v2 as I now have a more beefy model but when I complete a factory default and then select 'erase' during setup vi...
Jul 18, 2014Guru - Experienced User
"latest" is not a very informing answer. It'd be more helpful if you stated the version.
In any event, a factory reset should be sufficient. If you actually want more than that, then the simplest thing to do is connect the disks to a windows system and zero them using vendor tools (seatools for seagate, lifeguard for western digital).
