ndalby
Jul 17, 2014Aspirant
NasDuo v2 Secure Erase
HI All, Bit of weird one this (at least to me). I'm getting ready to sell my NasDuo v2 as I now have a more beefy model but when I complete a factory default and then select 'erase' during setup vi...
ndalby
Jul 18, 2014Aspirant
StephenB wrote: "latest" is not a very informing answer. It'd be more helpful if you stated the version.
In any event, a factory reset should be sufficient. If you actually want more than that, then the simplest thing to do is connect the disks to a windows system and zero them using vendor tools (seatools for seagate, lifeguard for western digital).
Unfortunately I was at work so couldn't say the exact version I had other than it was the latest version available for download for a v2 Duo (inc Raidar), which I thought would be listed on the site...sorry
My original plan was to format via Mac disk utility but my sata USB reader couldn't read the HDD's as anything other than 1tb HDD.
