netghiro
Aug 14, 2015Aspirant
nasready 312 and JBOD / no RAID setup
Hi, I'm thinking of buying a readynas 312 unit. I was just wondering can I install in it 2 different drives (a 4TB drive and a 8TB) and use them as 2 different btrfs volumes? Maybe I'm not using t...
- Aug 14, 2015
Shouldn't be any problems, just disable xraid from the volumes tab, then create two separate volumes and you're good to go :-)
Edit; Not sure if the 312 can handle any 8TB drives though - on the official compatibility list there's only a 6TB drive, WD RED WD60EFRX.
Danthem
Aug 14, 2015NETGEAR Employee Retired
Aug 15, 2015Guru - Experienced User
If you are talking about the Seagate archival drive (ST8000AS0012), then you should know that:
(a) It might not fit into the disk tray w/o removing some plastic nubs from the tray (not sure)
(b) the sustained write speed of that particular drive is extremely slow.
It is designed for cold storage applications, not a NAS (and Seagate recommends against using it in a NAS). Some users have done it anyway, and some of them have reported back confirming the slow write speed.
IMO You are better off with a WD60EFRX.
- netghiroAug 18, 2015Aspirant
StephenB wrote:If you are talking about the Seagate archival drive (ST8000AS0012)
Yep, which is the one with hardware encryption, and then the ST8000AS0002 which should be cheaper.
In case it would be just for storing movies (on a single disk volume, no raid), but not sure if it's a good idea like you said. Apparently also every scrub by btrfs may shorten the disk life.
Thanks for your help and informations!
I actually just found this thread:
- mdgm-ntgrAug 18, 2015NETGEAR Employee Retired
If you run an excessive number of scrubs then it may shorten a disk's life. If you run scrubbing say every 2-3 months that's much more reasonable.
Scrubbing can only detect problems but not fix them if you are using JBOD / RAID-0.
You may wish to have a read of http://kb.netgear.com/app/answers/detail/a_id/26941/~/free-space-on-btrfs-volumes---an-overview-of-relevant-maintenance-tasks
