jwram
Aug 08, 2012Aspirant
Need help getting ftp to work :/
Hi there.. Im experiencing some problems with FTP on my readynas duo and I thought I would check here to see if anyone has any ideas.. The appartments where I live all get internet from the same com...
jwram
Aug 09, 2012Aspirant
StephenB wrote: A couple of questions:
(a) what FTP client are you using? Is it set up to use 2AAA1 as the main port?
(b) By "public IP" do you mean 10.200.212.5, or the external IP address of the building (should be the latter)
(c) Are you testing FTP from inside your apartment or outside over the internet?
a) Using firefox and/or totalcommander
b) I mean external (http://www.whatsmyip.org/)... when trying to connect to it i use "externalip:22121"
c) Testing from inside my appartment
- Jan 17, 2024Retired_Member
