jwram
Aug 08, 2012Aspirant
Need help getting ftp to work :/
Hi there.. Im experiencing some problems with FTP on my readynas duo and I thought I would check here to see if anyone has any ideas.. The appartments where I live all get internet from the same com...
Aug 09, 2012Guru - Experienced User
Ok. I use FileZilla myself as the client.
You need to test again over the internet (outside the apartment). The masquerade address gets in the way for local LAN connections. In addition, 22121 is probably not being forwarded to 21000, because you are not connecting externally.
If you need to use FTP inside the apartment as well as outside, I suggest using the FileZilla client. That particular client will work even if masquerading is off. (if the passive port IP address is private, FileZilla will ignore it by default, and use the external IP it sees in the TCP connection). Not sure if totalcommander does that trick, I haven't used it.
If you want to try that,
-set the NAS to use port 22123 as the main port, and 22124,22125 as passive ports
-turn masquerading off (use the local address / nas name for in that field).
-connect as externalip:22123
This assumes that despite the "passive ftp" comment in your port list, the apartment does not have a firewall that actually validates the protocols on the forwarded ports.
- Jan 17, 2024Retired_Member
