jwram
Aug 08, 2012Aspirant
Need help getting ftp to work :/
Hi there.. Im experiencing some problems with FTP on my readynas duo and I thought I would check here to see if anyone has any ideas.. The appartments where I live all get internet from the same com...
jwram
Aug 09, 2012Aspirant
It works with no problem on my linux pc when i simply access the ftp server with nautilus and doubleclicks the movie..
The player buffers for 3 secs and start playing :)
On windows though.. the only way Ive gotten it working is by using XMBC but even then its not running at smooth as I would like :(
edit: I found that if I use netdrive, I can make my FTP look like a partition and have everything working smoothly.. gr8 :D
- Jan 17, 2024Retired_Member
