network23
Mar 18, 2013Aspirant
Need help getting permission to save to USB EXT3 drive
I've been having some troubles with my NV+ and need to back it up before doing a factory reset. Transferring files over the network is too slow (1-3MB/sec) and I thought directly connecting a USB drive would provide a faster connection.
I connected the drive directly to the NV+. In Frontview, I formatted the drive to EXT3 and downloaded/installed Ext2Fsd (found here http://www.webupd8.org/2011/08/access-ext4-ext3-or-ext2-partitions-in.html). In Windows 7 I can see and mount the drive. I can even see the contents, but any attempt to transfer files to the drive results in the message "You need permission to perform this action".
I've set the drive in CIFS to default access Read/Write, allow guest access, and automatically set permissions on new files and folders to Group: Read/Write and Everyone: Read/Write. I still can't move files into the drive.
Any suggestions?
Any suggestions?
Yes. NTFS transfers will be slower, so this may only be helpful as a test.network23 wrote: ...Are you saying, plug the drive into my PC, format it there, and then try to connect it directly to the NV+ and attempt to transfer the files via the Frontview Backup functionality?
Do you have files > 4GB? If not, you could alternatively use fat32. - network23AspirantOkay. Will try to format NTFS tonight.
Files over 4GB? I'm not sure. Probably. - network23AspirantDid not work.
I formatted the drive NTFS and connected it back to the NV+. Frontview reports no USB drive connected.
- Jan 17, 2024Retired_Member
