chris_bfd
Jun 09, 2021Aspirant
Need help recovering ReadyNAS Ultra6 (RNDU6000)
I attempted to upgrade my Ultra6 to OS6 and bricked it in the process. After several hours of "updating FW" in the display, I power cycled it. Now when I power it up again it displays the ReadyNAS l...
mdgm
Jun 15, 2021Virtuoso
The update should work. There are ways to troubleshoot why it's not working using SSH when booted normally or telnet (tech support mode).
If the prep add-on is installed prior to the R4toR6 image it should reboot multiple times and do a factory reset at the appropriate time. If you don't install the prep add on then it should reboot multiple times (I think) and eventually get stuck and you would need to do a factory reset using the boot menu.
Have you checked the output of
# dmesg
shortly after booting to see if it's reporting any problem with the internal flash?
Sandshark
Jun 15, 2021Sensei
I don't recall the conversion re-booting multiple times. There is the standard re-boot you have to do to initiate the actual update, just as with any other, then the factory default. Without the Prep add-on, it does lock up in the update process after the re-boot. I believe it successfully writes the update to the flash but then cannot do so to the OS volume and hangs there. I don't recall what the displayed message is at that point, but it may just be "Updating".
