chris_bfd
Jun 09, 2021Aspirant
Need help recovering ReadyNAS Ultra6 (RNDU6000)
I attempted to upgrade my Ultra6 to OS6 and bricked it in the process. After several hours of "updating FW" in the display, I power cycled it. Now when I power it up again it displays the ReadyNAS l...
tunesmithers
Mar 14, 2024Guide
I am in a similar boat this original poster was in. I can create the USB boot disk, but the unit just sits with ReadyNas on screen and no restart. However, my unit will boot up and I can see all is good in Frontview. The issue is my admin password stopped working. I set up the password recovery (via email) but I never get the email. Assuming they stopped supporting that when they stopped making this product. I have followed this thread and tried most of it (I don't know what that Telnet idea is... I'm not super savvy.
I also tried holding the reset to get to the boot menu, but it never shows up. It just loads normally.
I, however, do NOT have a full backup of the data on the drives and just wondering if I can do anything to get to the data (i.e. pull the drives into another (supported, newer) device.
Any thoughts or advice would be greatly appreciated.
Mar 15, 2024Guru - Experienced User
I am confused on this, since logging to Frontview requires the NAS admin password. Can you clarify exactly what stopped working?
- tunesmithersMar 15, 2024Guide
Sorry for the confusion. I said Frontview, when I meant the RAIDr status screen that shows the MAC address, Model, Host Name, IP address and the status of drives, etc. The information window shows 4.2.31 which I assume is the NAS firmware.
The issue started when I tried to login in using my admin login and password. It just stopped working. I tried using the password_recovery (via email method) that I had set up. No email ever comes (however, I am curious if that resets the password on my machine). Bottom line is that I can't login.
I was reading through how to change the password, and one of the suggestions was to do an OS reinstall (so I don't lose data). I followed the instructions from netgear (holding the reset button) and that literally does nothing. It just boots normally.
So then I followed in this thread and tried to use the USB recovery tool for 4.2.31 but no dice. I've tried 4 or 5 USB sticks, looking for older ones (as suggested). It would just say "ReadyNAs" on the device LCD but it never reboots, and I never get to the option of a usb recovery or anything. I found in a different post that even if it just shows "ReadyNas on the screen, that it could work, but it doesn't seem to be.
I can see the shares through Windows explorer but whenever I click on them it is asking me to log in. So I feel pretty good that all the data is there, I just can't get to it.
Any help would be greatly appreciated.
I should also note that I can actually access a few of the shares on the NAS through windows explorer and access the files on those shares. It's just my main share (backup) that is requiring the password. But of course, that's the share I am most anxious to get into.
- StephenBMar 15, 2024Guru - Experienced User
Are you saying the instructions on pages 28-29 fail?
I suggest trying the (similar) instruction for tech support mode, and see if that works. If it does, that would a one avenue for offloading data.
Were you also trying to convert the NAS to run OS-6?
(sorry, I am not sure how to include your comment in my response without copy and paste. When I hit reply to your comment it doesn't show your comment)
Yes. The boot menu never shows up. So, I can't get to tech support mode or any other mode. It just boots normally. I've held the paperclip on that switch for a variety of time durations and simply can't get it to start any boot menu.
No. I was just trying to login in and then started OS reinstall process with 4.3.2 with the USB key. No luck.
