jelockwood1
Oct 10, 2024Guide
Need help with XRaid2 problem on ReadyNAS Pro running RAIDiator 4.2.31
It is of course my own fault for not having a backup but the following happened. I had a 6 bay ReadyNAS pro as above running RAIDiator 4.2.31 with six 4TB drives. Whilst the logs showed an increa...
Oct 10, 2024Guru - Experienced User
jelockwood1 wrote:
I had a 6 bay ReadyNAS pro as above running RAIDiator 4.2.31 with six 4TB drives. Whilst the logs showed an increasing number of ATA errors the system was at that point working. Due to the increasing number of errors I decided to kill two birds with one stone and replace all the drives with 6TB drives by swapping one at a time and allowing re-syncing to occur. I had successfully swapped five of the drives and was doing the final drive and re-syncing again when the fifth drive completely died whilst it was syncing the sixth. This meant effectively two bad drives at the same time.
One complication is that 4.2.x systems can't be expanded over 16 TiB.
6x4TB RAID-5 would normally give you a 20 TB volume. If you created the volume by installing all 6 disks at once, I believe you'd get the full 20 TB size (since the all the disks are of equal size, so the volume doesn't actually expand). But the expansion to 6x6TB (30 TB volume) should have failed.
The usual mount procedure in tech support mode is
vgscan
vgchange -a y
mount /dev/c/c /c
Though it might be safer to do the mount read-only
mount -o ro /dev/c/c /c
So you could reboot into tech support mode and try that.
If you can figure out what 4 TB disk was in slot 6, you could also try assembling with the four 6TB drives and the original drive 6.
The other pathway is to use RAID recovery software in a Windows PC. You'd need an enclosure (~$200 USD). R-Studio is one option for recovery software ( https://www.r-studio.com/ )
FYI, after you recover the data, you should consider converting your NAS to run OS-6. That doesn't have the expansion limits that 4.2.x firmware has.
