jelockwood1
Oct 10, 2024Guide
Need help with XRaid2 problem on ReadyNAS Pro running RAIDiator 4.2.31
It is of course my own fault for not having a backup but the following happened. I had a 6 bay ReadyNAS pro as above running RAIDiator 4.2.31 with six 4TB drives. Whilst the logs showed an increa...
jelockwood1
Oct 10, 2024Guide
I am at this stage far less concerned with storage expansion and may indeed look at v6 later for that.
Steve, as I indicated vgscan is not finding a volume i.e. c and hence it is not possible to do vgchange or mounting. Also (not mentioned) likely for the same reason there is no /dev/c/c/ device
You might have been confused by my referring to the fact I have a second identical but working unit and it does list the c volume and have a /dev/c/c/
Oct 10, 2024Guru - Experienced User
Understood. I raised the expansion issue in the first post, because the failed expansion might complicate recovery efforts.
You might have better luck with the 4 larger disks + the original disk 6. The volume would be out of sync no matter what you do, so that it is part of the puzzle.
Though honestly I think your best option is recovery software.
