schnax
Apr 14, 2017Apprentice
Need to downgrade from 6.7.0 to 6.6.1
Anyone knows how to downgrade from 6.7.0 to 6.6.1? Our NAS is unstable and we're unable to access our files with Egnyte.
- Apr 14, 2017
6.7.0 is a major upgrade.
For the most part there would be workarounds for issues encountered e.g. OOMing.
jak0lantash
Apr 14, 2017Mentor
schnax wrote:Anyone knows how to downgrade from 6.7.0 to 6.6.1?
"Devices updated with 6.7.0 firmware should not be downgraded to earlier firmware versions."
Short answer: you cannot.
Long answer: maybe you can, but it's incovenient, dangerous and unknown.
The "cleanest" way to downgrade would be to load the older firmware onto the flash via USB Boot Recovery, then to reset the NAS to Factory Default, wiping everything (all data gone). And it's, of course, no without risks. So I'm guessing, you don't want to do that.
Installing an older image on the NAS using the GUI is sometimes possible, but it's not supported and you may create some untested situations, such as issues with services or even complete inability to boot the NAS. It's untested, anything can happen...
