Martcart78
Mar 10, 2020Aspirant
Net Gear 3100 nas
Hi i have installed nww hdds 2tb, why am i getting a no disk detected, i have done a factrcy reset , reinstalled os, still getting this message,pleaase can some one help me (see pic)
Martcart78
Mar 12, 2020Aspirant
Hi
I am using seagete sata drives. Was all working unitill I have to replace the bios battery. Now I just get no drives detected.
Sandshark
Mar 12, 2020Sensei
You are getting a lot more than that. The IP address is the fall-over address (192.168.168.168) and the model and firmware fields are empty. But this is a RAIDiator 4.2.x system, and you really should be using RAIDar 4.3.8 to set up the NAS, not whichever version that is you are using. I'm not sure how the later RAIDar acts prior to volume creation on a 4.2.x based NAS, as I no longer have any active.
Since you are starting over, you may want to take this opportunity to convert your NAS to OS6.
- Martcart78Mar 12, 2020AspirantThanks for your advice. How do I swap over to os6 then please
- SandsharkMar 12, 2020Sensei
- StephenBMar 12, 2020Guru - Experienced User
Sandshark wrote:
Actually the instructions aren't there, just the download links. The steps are:
(Optionally) make sure the latest BIOS is installed before you do the conversion. To do this you install http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin as an add-on and reboot the NAS. Do this after you backup the NAS. This isn't necessary, but if you want to update the bios it is easiest to do it prior to converion
Basic instructions for the conversion itself are
- BACKUP, BACKUP, BACKUP
- Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
- Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
- After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
- Go through the setup process on the converted NAS
- Update the NAS to the current OS 6 (check for updates will work).
- Restore files from the backup.
Netgear won't provide paid support on a converted NAS. There is a small risk that the process could fail, and if that were to happen it might not be possible to get the NAS running again.
