CABird_UK
Jul 05, 2021Tutor
netgear nas 214 boot stuck 99 percent
NAS 214 fails to boot beyond 99%. Tried reset a few times no resolution. Referred to below Solved: ReadyNAS 314 stuck at booting 99% - NETGEAR Communities And manual pages 74 -75 and still ...
michaelkenward
Jul 06, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but there isn't much in common between a router and your ReadyNAS, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
ReadyNAS Network Storage: Official NETGEAR Community
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
CABird_UK
Jul 06, 2021Tutor
Thank you, michaelkenward I appreciate you taking the time to respond.
I agree with you support navigation is an extreme challenge.
Hopefully, a solution can be found although I suspect its a factory reset.
- michaelkenwardJul 06, 2021Guru - Experienced User
The level of understanding and willingness to help people with problems seems to be higher over in the NAS area. Perhaps because NAS stores are not cheap boxes sold to consumers who think that when they spend $100 on a device and they can demand lifetime support from a team of dedicated Netgear specialist technicians.
