CABird_UK
Jul 05, 2021Tutor
netgear nas 214 boot stuck 99 percent
NAS 214 fails to boot beyond 99%. Tried reset a few times no resolution. Referred to below Solved: ReadyNAS 314 stuck at booting 99% - NETGEAR Communities And manual pages 74 -75 and still ...
CABird_UK
Jul 06, 2021Tutor
Thank you, michaelkenward I appreciate you taking the time to respond.
I agree with you support navigation is an extreme challenge.
Hopefully, a solution can be found although I suspect its a factory reset.
michaelkenward
Jul 06, 2021Guru - Experienced User
The level of understanding and willingness to help people with problems seems to be higher over in the NAS area. Perhaps because NAS stores are not cheap boxes sold to consumers who think that when they spend $100 on a device and they can demand lifetime support from a team of dedicated Netgear specialist technicians.
