CABird_UK
Jul 05, 2021Tutor
netgear nas 214 boot stuck 99 percent
NAS 214 fails to boot beyond 99%. Tried reset a few times no resolution. Referred to below Solved: ReadyNAS 314 stuck at booting 99% - NETGEAR Communities And manual pages 74 -75 and still ...
Jul 06, 2021Guru - Experienced User
Unfortunately, failure to fully boot can have lots of different causes.
Can you clarify more precisely what you did when you "tried reset"? Did you mean a factory default, an OS reinstall, or perhaps something else???
Also, what firmware are you running?
