TeMorituriNZ
Apr 05, 2016Aspirant
Netgear NV+ Booting for 36 hours
Hi I have a 2009 ReadyNAS RND4000 NV+ which suddenly has hung itself on booting Initially it would not show anything in the LCD and I had to phjysically unplug the power supply to get it to resta...
- Apr 06, 2016
Guys {elation},
I waited over 30 hours but the NAS just sat there with the LCD displaying booting so then I gave in and pulled the Drive in Bay 1. I repowered and it went through the same boot routine but then jumped into check FS and was at 5 % in just a few minutes. This morning when I came down the NAS had booted completely and advised me I was missing a drive which I have promptly replaced :smileyvery-happy:
RAIDar is showing me status and firmware (4.1.14)
Resynch is 5% advanced with a finish time in about 8 hours
Thank you all for the comments...they pointed the way and gave me the confidence to be patient.
It helped that nothing critical on the NAS had not been backed up so I wasnt stressing about loss ...but looking through the files I am glad I have them all back.
Thank you once again
Apr 05, 2016Guru - Experienced User
I'd try booting w/o the FS check. If that works, back up the unit and do a factory reset/restore.
Also, check the SMART stats on the disks.
JennC
Apr 05, 2016NETGEAR Employee Retired
Hello TeMorituriNZ,
You can try Skip Volume Check from the boot menu then once it allows you to access the FrontView, download the logs and check reallocated sector count and ATA errors. If you will be able to access the files. back up asap.
Welcome to the community!
