Dan-Wabwile
Nov 15, 2023Aspirant
netgear readynas 316no volume exists. Netgear recommends that you create volume before configuring
Hello , I am getting the error netgear readynas 316 no volume exists. Netgear recommends that you create volume before configuring other settings. I have a readyNAS 316 with 6 disks each 3TB and o...
Nov 15, 2023Guru - Experienced User
Dan-Wabwile wrote:
The device is still recognising 13.2 storage. 6 disks by 3tb should be 18TB.
The capacity rule for single redundancy XRAID is "sum the disks and subtract the largest" - in your case that is 15 TB (using 1000*1000*1000*1000 bytes per TB). The remaining 3 TB is used for parity blocks, which allows any single disk to be reconstructed from all of the others.
15 TB is the same as ~ 13.62 TiB (1024*1024*1024*1024 bytes). Which is what your screen shows.
As far as the missing disk 1 and 4 goes, it is difficult to tell what is happening from the screenshot. The best strategy now is to power down the NAS and test the disks in a Windows PC using seatools. Label the disks as you remove them from the NAS, so you can put them back in the correct slots. Don't power up the NAS until all disks are back in place.
I can also take a look at the log zip if you like. If you are interested in that, send me a private message (PM) that includes a download link for the log zip (saving the zip in dropbox, google drive, etc). Make sure the link permissions are set so that anyone with the link can download.
Dan-Wabwile wrote:
How do you go about it in order not to lose data? Does it mean the new disk is faulty?
FWIW, I always test new disks in a PC before putting them into the NAS. I do the full (long) non-destructive read test, and then follow that up with a full erase test. I have had some new disks that pass one of these tests, but fail the other.
As far as replacement goes, I hot swap the disks (removing the old one and inserting the new one with the NAS running).
Still, your data is more vulnerable to loss during a disk replacement than at other times. So I do recommend making sure your backup is up to date before manipulating disks.
Dan-Wabwile
StephenB Actually I have enslaved the new disk on the desktop but it was not able to be detected nor be read. I have connected externally on my laptop but still no detection. So i suspect the NAS could not rebuilt the data while on 4 disks. So my worry is if the data is lost. I shutdown the NAS since i never wanted any further damages. Am getting a new disk then share the feedback with you.
- StephenBNov 16, 2023Guru - Experienced User
FYI, Windows can't mount the disks due to the linux formatting, but the vendor tools (seatools in this case) can still detect them. Also, they should show up in the Windows Disk Manager.
So if you didn't check with those tools, it is worth another look.
If the new disk has failed out of the box, I suggest exchanging it for a Seagate Ironwolf instead of another surveillance-purposed drive.
