Hitcap
Jan 10, 2014Aspirant
Netgear ReadyNas DUO performance: conclusion
Hello everyone, After days spent on forums and attempts to reach solution for really horrible feeling from ReadyNas Duo performance speed, I feel an urge to make a summary of my experience. I bo...
Jan 10, 2014Guru - Experienced User
The duo you purchased was obsolete when you purchased it - Netgear replaced it in late 2011. It was very competitive in its day, and I still use mine for back up.
Product reviews (e.g. http://www.smallnetbuilder.com/nas/nas- ... l=&start=6 ) and Netgear's published performance tests showed that it's peak read speed was ~30 MB/s. If you were seeing higher numbers than that somewhere, then you were likely confusing the duo v2 with the older v1 you actually purchased. The branding (duo and duo v2) makes them easy to confuse.
I don't what was going on with jumbo frames on your network, but you wouldn't the first poster to discover that they always don't help performance. Usually we do suggest that people with performance issues try turning them off.
