uwaisrehman
Aug 13, 2021Aspirant
Netgear ReadyNas Duo V2 - no disks detected
Hi I have a ReadyNas Duo V2 with a 2TB installed. This device has worked absolutley perfectly with no issues for a number of years UNTIL TODAY. I was streaming some media from the device and all of...
uwaisrehman
Hi Stephen
The NAS is definitely a v2 and is running the latest firmware.
In regards to the blinking, on boot the power light comes on and then the activity light constantly blinks. No other lights blink.
Can I use a SATA to USB to connect the hard drive to my Windows laptop.
Thanks for the help.
Thank you
Uwais
Thank you
Uwais
Aug 13, 2021Guru - Experienced User
Yes.
- uwaisrehmanAug 13, 2021AspirantIs there anyway of reviving the NAS?
Previously it was working perfectly. No idea what caused the fault- StephenBAug 13, 2021Guru - Experienced User
uwaisrehman wrote:
Previously it was working perfectly. No idea what caused the faultThe chassis isn't repairable - the only thing that can be replaced is the power adapter.
But based on the info you provided, I think it's likely that the NAS is ok, and the disk failed.
If you have a spare disk (with no useful data on it), you could try inserting it into the NAS, and see if it is detected or not.
