walkz187
Mar 10, 2023Aspirant
netgear readynas nv+ stuck booting after a power outage
Hello, I was hoping someone might be able to point me in the right direction to getting my ReadyNAS back up and running. Yesterday my home had a power outage. I turned on the ReadyNAS and it ju...
Mar 10, 2023Guru - Experienced User
I am wondering what firmware you are running.
Also, do you have ssh enabled?
- walkz187Mar 10, 2023AspirantI don’t know the exact firmware version but it was the latest and most up to date for an old ReadyNAS NV+.
Is there a way I can check this given the current situation?- StephenBMar 10, 2023Guru - Experienced User
walkz187 wrote:
Is there a way I can check this given the current situation?RAIDar should tell you.
I am trying to make sure we have the correct model.
The original NV+ (called v1 here)
- says "ReadyNAS NV+" on the front panel
- runs 4.1.x firmware.
The NV+ v2
- says "ReadyNAS NV+ v2" on the front panel
- runs 5.3.x firmware.
It will be harder to recover data from the 2x2TB RAID-0 volume.
