walkz187
Mar 10, 2023Aspirant
netgear readynas nv+ stuck booting after a power outage
Hello, I was hoping someone might be able to point me in the right direction to getting my ReadyNAS back up and running. Yesterday my home had a power outage. I turned on the ReadyNAS and it ju...
P-Dog
Sep 07, 2023Tutor
I have the same issue, my house had a power outage. I have my RN31400 connected to a back up battery. When I got home I turned it back on and it's stuck on 99% boot. Not reachable through ready cloud, nor to the IP address. But I am still able to see and open the mapped folders. I have done a normal boot, I have reinstall the SO, but nothing.
Any help will be appreciated.
Sep 07, 2023Guru - Experienced User
But a different ReadyNAS, which does make a difference.
Expected. since Netgear turned off ReadyCloud in July.
P-Dog wrote:
have my RN31400 connected to a back up battery. When I got home I turned it back on and it's stuck on 99% boot. But I am still able to see and open the mapped folders.
You are saying that you have access to the files? If you do, then the first step is to back them up. The data is definitely at risk.
Is RAIDar giving you any status information?
When you say "IP address", are you saying that accessing the web ui using https://nas-ip-address/admin fails?
Also, what firmware are you running on the NAS?
- P-DogSep 09, 2023Tutor
********Yes, I have access to the files, I am in the process of backing them up to my Unraid Server.
********The status I get is "Management service is offline"
********Yes when I try to access the nas through web ui, it fails. I get the generic message "ReadyNAS Admin Page is offline"
********I am running 6.10.8
