EndersShadow
Aug 22, 2024Aspirant
Netgear ReadyNAS power up issue
Have had a Netgear ReadyNAS (RND-2A) running for years. Over time I had to replace the PSU once when it wouldn't start and that resolved the issue. Earlier this week it wouldn't power on. Replace...
EndersShadow
I’m pretty sure I’d upgraded to OS6 a year or so back.
Thanks for the suggestions. Someone recommended the HP MicroServer line, something like the Gen8, Gen10 Plus (v2)
Aug 22, 2024Guru - Experienced User
I am seeing a 2022 post where you said you did this.
OS-6 uses the BTRFS file system. You can manually mount the data volume in a linux system that has both MDADM and BTRFS installed.
The other option is to use data recovery software that supports BTRFS - for example ReclaiMe
- EndersShadowAug 22, 2024AspirantTotally forgot I’d put that thread out there.
Thanks for the tip. Will go one of those two routes.- SandsharkAug 23, 2024Sensei
A used replacement ReadyNAS is also at least a temporary solution. Since you were running OS6, you can use a legacy NAS upgraded to OS6 or a native OS6 NAS. Note that your current caddies will fit in either (except rack mount models) -- which is good since a lot of used ones sell without them. (The opposite is not true, BTW.) Your PSU will also work with any 2-bay ReadyNAS.
