muxyd
Jan 02, 2016Aspirant
Netgear readynas rnd2000 recovery
Hi Guys, I have a Netgear readynas rnd2000 bought some time in 2010. I have 2 2TB hdd configured as RAID0. So the storage was 4 TB. Now it seems the device stopped working. it is not getting d...
Jan 02, 2016Guru - Experienced User
You cannot migrate the disks to any current NAS, but you could look for a used duo v1 or used nv+ v1.
If the NAS isn't powering at all (no lights, etc) it might be the power brick. If you google, you can find replacements fairly easily.
RAID-0 is particularly vulnerable to disk failures (though that doesn't seem to be your issue). So if you do manage to get the data back, you should definitely put a backup plan in place.
muxyd
if i buy a second-hand NetGear ReadyNAS Duo 2-Bay (Diskless) RND2000 and connect both my HDDs, will it start working right away?
Or is there any setup/configurations that has to be made?
thanks...
- StephenBJan 02, 2016Guru - Experienced User
Before you get a used NAS, I'd try powering down and removing both disks (labeling by slot). Then power up. If RAIDar finds the NAS and reports "no disks" then the problem is likely with the disks, and not the chassis.
If that turns out to be your situation, get a scratch disk and try doing a factory install with only that disk in place. If the works normally, then for certain the problem is on one or both hard drives.
thanks...
The NAS boots from an OS partittion on the disks. The boot flash also includes an install package, and if the firmware version in the flash differs from the OS partitoin, the system will attempt to overinstall the flash version (either upgrading or downgrading the OS version on the disks).
Normally this is not a problem - settings and data are preserved. Though if you are migrating disks to a NAS and don't know the firmware version that was installed, then it is best to start with a scratch disk. Then after the default installation you install firmware that matches the old NAS. The result is that the flash package matches what is on the disks, and the system won't attempt to overinstall.
Also label the drives by slot before you remove them - you want to preserve the order.
- muxydJan 02, 2016Aspirant
It was already tried out the below
1. removed both the disks and tried booting.
2. Tried booting the device with only disk in slot1.
3. Tried booting the device with only disk in slot2.
4. Tried booting the device after swapping the disks.
but none worked. the device is not detected by RAIDar.
Even i tried connecting the device directly to my laptop ( using RJ45 cable), but the network device icon my machine showed the red cross.
when i connected the HDDs, the partitions were detected properly and dont think there is any phyical damages
- mdgm-ntgrJan 02, 2016NETGEAR Employee Retired
If you purchase a new ReadyNAS e.g. RN312, you could contact support and pay for an attempt to recover your data.
You would need somewhere for the data to be backed up to and to wait for support's instructions on how to set things up for them to do their work.
