muxyd
Jan 02, 2016Aspirant
Netgear readynas rnd2000 recovery
Hi Guys, I have a Netgear readynas rnd2000 bought some time in 2010. I have 2 2TB hdd configured as RAID0. So the storage was 4 TB. Now it seems the device stopped working. it is not getting d...
muxyd
Thanks mdgm..
If I can arrange a temporary NetGear ReadyNAS Duo 2-Bay (Diskless) RND2000 and connect both my HDDs, will i be access my files??
If so, I know someone who has one which I may be able to borrow for someone. But it is not easy. So what to know if it works before I try it out..
Please advice.
Please advice.
- mdgm-ntgrJan 02, 2016NETGEAR Employee Retired
Impossible to know for sure before you give it a try.
It must be the same kind of Duo: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Does the system show on RAIDar if you try booting to tech support mode?
