Battlesloth01
Nov 24, 2018Aspirant
NetGear ReadyNAS RNDP600U
Hello,
TO be clear there is no data on my drives these are 6 brand new drives, no data at all its a new setup.
My question was as a previous drive has failed, I bought 6 new 3Tb Hdd, after do...
- Nov 25, 2018
Hi @Battlesioth01
Welcome to the Community!
What is the firmware installed on your RNDP600U?
If you have OS 4 installed try using default Username: admin Password: netgear1 but if you have upgraded it to OS 6 then Username: admin Password: password should work.
Hope this helps!
Regards
Marc_V
Nov 25, 2018NETGEAR Employee Retired
Hi @Battlesioth01
Hope this helps!
Regards
- Battlesloth01Nov 25, 2018Aspirant
It is RAIDiator 4.2.31 btu appears netgear1 has worked thanks back to restored state
