Battlesloth01's avatar
Nov 24, 2018
NetGear ReadyNAS RNDP600U
Hello, TO be clear there is no data on my drives these are 6 brand new drives, no data at all its a new setup.   My question was as a previous drive has failed, I bought 6 new 3Tb Hdd, after do...
  • Marc_V's avatar
    Nov 25, 2018
    Hi @Battlesioth01
    Welcome to the Community!
    What is the firmware installed on your RNDP600U?
    If you have OS 4 installed try using default Username: admin Password: netgear1  but if you have upgraded it to OS 6 then Username: admin Password: password should work.
    Hope this helps!
    Regards
ProSupport for Business
