vikassingh
Sep 23, 2019Aspirant
Netgear RN2120v2
Not able to ping the device (RN2120v2).earlier it was working fine
Sep 24, 2019Guru - Experienced User
You have a rackmount model? What firmware was the NAS running?
What LED status are you seeing? (see pages 14ff here: http://www.downloads.netgear.com/files/GDC/RN2120/ReadyNAS_OS6_Rackmount_HWM_EN.pdf )
- SandsharkSep 24, 2019Sensei
Ok, so I hope you realize your statement is about as descriptive as "my car was runing this morning, now it's not -- what's wrong?"
A little more detail will go a long way in helping us help you figure out the problem. Any LEDs lit (front and NIC in the rear)? Fan sound normal? Anyting at all you did, or is on a schedule to be done, from working condition to not? Any changes in network configuration?
- vikassinghNov 01, 2019Aspirant
Hi
As per manual,LED status indicting OK status for hardware.No change has been performed for the network configuration.Fan sound is normal.
- StephenBNov 01, 2019Guru - Experienced User
What is the status of the ethernet LED (both on the NAS and the switch/router)?
Have you tried using RAIDar to detect the NAS status? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
Is the NAS still covered by warranty?
hi
As per manual, NAS LED status is showing OK.
IP address cant get ping and also MAC address not showing in list on arp -a command
