silence112
Sep 15, 2015Aspirant
netgear RNDP6000 pioneer edition booting problem.
Hello community Members. im having a problem with my nas i hade a power surge due a short circuit in my microwave. now i have the problem when i switch the main power switch on the back off ...
- Sep 15, 2015
The power supply may have been damaged by the power surge.
You could try getting a replacement PSU and extender cable.
mdgm-ntgr
Sep 15, 2015NETGEAR Employee Retired
- silence112Sep 16, 2015Aspirant
Hi thanks for the reply.
could u tell me more information about the parts needed for this like part numbers or something like that?
couse than i would like to try this as a solution if it is not to expensive.
best regards.
Michael Damen.
- mdgm-ntgrSep 16, 2015NETGEAR Employee Retired
You can see some suggestions on the community as to what you could use.
- silence112Sep 17, 2015Aspirant
Thanks For The Help.
unit is working perfectly again.
i used an old power supply i had laying around and atm it is laying next to the unit.
but the problem is gone now later on i will buy a new power supply
Thanks Again.
Best Regards.
Michael Damen.
