ylafont
Oct 04, 2015Aspirant
Netword Performance issuse
Need some guidance on a Networking issues that started a few days ago and I am not sure how to how to troubleshoot. Problem - Every two minutes or so I lose the ability to access the internet, we...
ylafont
i am curious the bond0 and and tun10 interfaces.. are they supposed to be there?
NasOne:~# ifconfig -a
bond0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
UP BROADCAST RUNNING MASTER MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
eth0 Link encap:Ethernet HWaddr 00:1F:33:EA:50:95
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
Interrupt:16 Memory:ff6fc000-0
eth1 Link encap:Ethernet HWaddr 00:1F:33:EA:50:94
inet addr:192.168.101.3 Bcast:192.168.101.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:14079467 errors:0 dropped:7 overruns:0 frame:0
TX packets:2106931720 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3083618709 (2.8 GiB) TX bytes:2046929944846 (1.8 TiB)
Interrupt:17 Memory:ff7fc000-0
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:26411 errors:0 dropped:0 overruns:0 frame:0
TX packets:26411 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1811103 (1.7 MiB) TX bytes:1811103 (1.7 MiB)
tunl0 Link encap:IPIP Tunnel HWaddr
UP RUNNING NOARP MTU:1480 Metric:1
Oct 04, 2015Guru - Experienced User
I see both interfaces on my pro (though in my case I use bond0). I am wondering if tun10 is set up for remote.
What add ons do you have installed?
- ylafontOct 04, 2015Aspirant
No add-ons install on the NAS.
to be on the safe side, I just turned off
Discovorry Services
ReadyDLNA
AFT protcol
FTP Protocol
The only services running are CIFS, HTTP, HTTPS
- StephenBOct 04, 2015Guru - Experienced User
If you have a scratch disk, you could remove the pro disks (labeling them by slot), and install the install disk.
Then see if the clean factory install has the same problem.
- ylafontOct 09, 2015Aspirant
Currently moving data of NAS to performe a reset. NAss has been one for over three years, no changes have been made. How coudl this have happend and more importantly how can it be prevented?
