Gura
Jan 23, 2011Follower
Network attached printer makes ReadyNas Duo unreachable
I've got a strange and annoying problem with my NAS and my network attached HP printer. Setup: 1 Readynas Duo (radiator 4.1.7) [cable] static ip, CIFS, ReadyDLNA, UPnP 1 HP Photosmart Premium C30...
dazzzerr
Mar 03, 2011Aspirant
Hi
I have a HP photosmart plus b210, with a readynas duo on my network. I have a very similar problem to the one you describe, did you resolve the issue ?
Actualy, my problem is that the readynas will not be visable/pingable or allow access through frontview while the printer is in the network. I have set all up with static ip's to avoid conflicts.
If you turn off the printer ( leave it off ) , then turn the readynas off/on .....the readynas is back, until I turn the printer on !
Any help appreciated.
Thanks :D
Thanks :D
