Kiwi20
Apr 09, 2016Follower
Network error code: 0x80070035
Hi I am unable to upload any files to the NAS since downloading windows 10. Every time I click on the NAS folder in the network it advises that windows can not access my NAS displaying error code...
jimmyv
Jun 26, 2016Aspirant
same problem here, cant connect to the drive maps, red crosses on the links under network. i can ping the address and connect to the management console but no access to the drive maps.
also readycloud cannot find my nas, cant figure out what the problem is exactly.
jimmyv
also im running a windows 10 and firmware 6.5.1
- jimmyvJun 26, 2016Aspirant
readynas cant find the nas and RAIDar has nog problem finding the nas.
- StephenBJun 26, 2016Guru - Experienced User
What model NAS and what firmware is it running?
problem solved, during testing the eth was changed from eth0 to eth1, after changing it back to eth0 with a ip address in the correct range, the problem was solved
