toby30938
Jul 12, 2017Aspirant
Network Issue between ReadyNAS and Router (AVM FritzBox 7490)
Hi there, we recently moved from an "old" Ultra2+ towards RN312. Migration was fine. But we have a major issue with our internet connection (Router is an AVM FritzBox) now. The connection run...
Hopchen
Jul 13, 2017Prodigy
You could use tcpdump to sniff the traffic. You just need to install and use through command line.
apt-get install tcpdump
As long as you are comfortable with the cli :)
Jul 13, 2017Guru - Experienced User
I was just thinking an app to take a trace might be handy sometimes. tcpdump is probably the right tool, since it outputs via pcap
- toby30938Jul 17, 2017Aspirant
Latest update. I switched the gateway to something stupid and it worked out the whole weekend. So it looks to me, that something from the 312 is messing up the router. I can leave it that way for some time, but a long term solution would be nice :)
Anyhow, thanks for the hint. I would not have thought of it...
- Marty_MJul 23, 2017NETGEAR Employee Retired
Hello toby30938,
When you say I switched the gateway to something stupid and it worked out the whole weekend. What exactly did you change? Is the NAS on static ip address or on DHCP?
Marty_M
NETGEAR Community Team- toby30938Jul 23, 2017AspirantHi, IP is Static. I just changed the Gateway and DNS IP to values outside our adressrange.
