toby30938
Jul 12, 2017Aspirant
Network Issue between ReadyNAS and Router (AVM FritzBox 7490)
Hi there, we recently moved from an "old" Ultra2+ towards RN312. Migration was fine. But we have a major issue with our internet connection (Router is an AVM FritzBox) now. The connection run...
Jul 13, 2017Guru - Experienced User
I was just thinking an app to take a trace might be handy sometimes. tcpdump is probably the right tool, since it outputs via pcap
toby30938
Jul 17, 2017Aspirant
Latest update. I switched the gateway to something stupid and it worked out the whole weekend. So it looks to me, that something from the 312 is messing up the router. I can leave it that way for some time, but a long term solution would be nice :)
Anyhow, thanks for the hint. I would not have thought of it...
- Marty_MJul 23, 2017NETGEAR Employee Retired
Hello toby30938,
When you say I switched the gateway to something stupid and it worked out the whole weekend. What exactly did you change? Is the NAS on static ip address or on DHCP?
Marty_M
NETGEAR Community Team- toby30938Jul 23, 2017AspirantHi, IP is Static. I just changed the Gateway and DNS IP to values outside our adressrange.
- Marty_MJul 24, 2017NETGEAR Employee Retired
Hello toby30938,
For the DNS address it is ok to use other DNS address but for the gateway it should be the gateway of the network. There is a possibility that this time you managed to set the correct gateway address.
Marty_M
NETGEAR Community Team- StephenBJul 24, 2017Guru - Experienced User
The idea here was to deliberately prevent the NAS from accessing the internet. Per the first post, something was creating an issue with the OPs overall internet service. He suspected the NAS, and turned it off. The problem disappeared. The next step was to intentionally misconfigure the DNS server and gateway, so the NAS couldn't access the internet - leaving the NAS running. The problem is still gone. So it would appear that the NAS is doing something that is creating congestion or otherwise stressing the internet service.
toby30938 - I think a good step now is to configure the DNS and gateway correctly, and see if the problem starts up again. That will confirm that it's caused by something on the NAS.
