yrntugolfn
Dec 20, 2013Aspirant
Network path not found
Here is my issue. Everything was working fine, Ive been using my ReadyNAS for about 2 years. Minor issues happen but they tend to fix with a restart. I access my ReadyNAS on a Mac and a PC running Win...
yrntugolfn
Dec 23, 2013Aspirant
Here are the ping results. It shows the IP address, not the name. I'll have to go over those other items you mentioned later today when I have a bit more time. Can you think of a reason why this happened all of a sudden?
Pinging 192.168.1.109 with 32 bytes of data:
Reply from 192.168.1.109: bytes=32 time=1ms TTL=64
Ping statistics for 192.168.1.109:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 1ms, Average = 1ms
Thanks a ton for all of the help so far!
