yrntugolfn
Dec 20, 2013Aspirant
Network path not found
Here is my issue. Everything was working fine, Ive been using my ReadyNAS for about 2 years. Minor issues happen but they tend to fix with a restart. I access my ReadyNAS on a Mac and a PC running Win...
yrntugolfn
Jan 06, 2014Aspirant
When I go into frontview Under Network>DHCP it says:
"The service is not available because your current IP or DNS addresses are obtained through a DHCP service. Configure them statically and isolate this device on a network that currently does not have a DHCP server to avoid conflicts."
Under Network>Ethernet1
"IPv4 assignment: Use values from a DHCP server" is selected.
Is this already correct or should I make a change or select "Renew Now" for the IPv4 assignment?
The router is a WRT54GL
