yrntugolfn
Dec 20, 2013Aspirant
Network path not found
Here is my issue. Everything was working fine, Ive been using my ReadyNAS for about 2 years. Minor issues happen but they tend to fix with a restart. I access my ReadyNAS on a Mac and a PC running Win...
Jan 06, 2014Guru - Experienced User
Network->interfaces->ethernet is the relevant configuration, and it is already correct.
I think the next step is to check to see if the carbonite folks are correct.
If you log into the router, you should be able to see all the devices that are connected.
If you can't figure it out in the router pages, try Advanced IP Scanner (http://www.advanced-ip-scanner.com/). That should show you all the devices you have turned on, and give you their IP addresses.
