cburgess002
Dec 08, 2021Aspirant
Network path was not found
I have 2 similarly configured ReadyNAS 2312 units and am getting a "Network path was not found" error when I try to connect to one of them from Windows Server 2016 and Windows Server 2019 without spe...
Dec 09, 2021Guru - Experienced User
What firmware are you running?
If you can't sort out what is going on with name resolution, one option is to just put them in the HOSTS file.
FWIW, I reserve the NAS IP addresses, and use the IP addresses in my NAS backup jobs.
cburgess002
Dec 09, 2021Aspirant
I was running the latest Long-Term Support Release (6.9.6), but upgraded to the most recent Stable Release (6.10.6) to see if it would fix the issue because the NAS that worked without issues had the most recent stable firmware. It is not a name resolution problem as I can map a drive if I first specify the username. The issue is that if I don't specify a username, Windows Server 2016 and Windows Server 2019 give a path not found error rather than asking for a username. For most things this isn't an issue, but it appears to be causing my backup software to fail when accessing the NAS. I just have no idea why one NAS is behaving different from the other. I thought that it might have something to do with insecure guest access being disabled on Windows (although it doesn't explain why one would work), but enabling it didn't help.
