cburgess002
Dec 08, 2021Aspirant
Network path was not found
I have 2 similarly configured ReadyNAS 2312 units and am getting a "Network path was not found" error when I try to connect to one of them from Windows Server 2016 and Windows Server 2019 without spe...
cburgess002
Dec 09, 2021Aspirant
I was running the latest Long-Term Support Release (6.9.6), but upgraded to the most recent Stable Release (6.10.6) to see if it would fix the issue because the NAS that worked without issues had the most recent stable firmware. It is not a name resolution problem as I can map a drive if I first specify the username. The issue is that if I don't specify a username, Windows Server 2016 and Windows Server 2019 give a path not found error rather than asking for a username. For most things this isn't an issue, but it appears to be causing my backup software to fail when accessing the NAS. I just have no idea why one NAS is behaving different from the other. I thought that it might have something to do with insecure guest access being disabled on Windows (although it doesn't explain why one would work), but enabling it didn't help.
Dec 09, 2021Guru - Experienced User
Have you tried creating running the Windows Credential Manager on the problem machines? Delete any credentials that are stored there for the NAS. Then try entering a new one (either with the username, or with the username and password).
- cburgess002Dec 09, 2021Aspirant
I had checked and there were no stored credentials on any of the systems. I also tried adding stored credentials and that worked as expected (but I didn't try my backup software with Windows stored credentials only with credentials stored in the backup software). I don't want to have Windows Credential Manager stored credentials for the NAS as it would give any malware that I might encounter access to destroy backups on the NAS.
- StephenBDec 09, 2021Guru - Experienced User
Did you try putting the username in the credential, but leaving the password out?
Great idea, I hadn't tried leaving the password blank, but I just did and explorer worked by asking for the password or "more choices" for a different user. When I did a "net use" with no username, it asked for both the username and password. So all of this is encouraging, but unfortunately I can't test out the backup software for 27 hours as I am in the middle of a full backup to the correctly behaving NAS. When the backup is completed, I will test it out with the troublesome NAS. If it works, I'll use it as a workaround, but still would like to find out why there is a difference between these two NAS units. I have also tested with 2 ReadyNAS 426 units, 2 ReadyNAS 316 units, and 2 ReadyNAS Pro 4 units and none of them exhibited the strange behavior, only 1 of the ReadyNAS 2312 units have the problem (although I did have to enable insecure guests access on the Windows servers to avoid a guest access error with the ReadyNAS 316s that I tested).
