PIERRESANT
Apr 07, 2016Aspirant
Network Speed on RN102
Hi, i have been running the NAS RN102 with 2 Western Digital RED Drives 2TB for the past 3 years without any problems. i am also running the latest version of firmware 6.4.2 recently when i...
- Apr 07, 2016
Hi PIERRESANT,
Is on your NAS the Antivirus on ? IF yes i will tray the solution given in this document.
http://kb.netgear.com/app/answers/detail/a_id/30436or you can Try do update the Firmware to the beta version 6.5.0
Before updating you should read This article
PIERRESANT
it seems updating the antivirus using the steps in this link fixed the problem
hopefully it will continue to work perfectly
JennC
Apr 07, 2016NETGEAR Employee Retired
Hello PIERRESANT,
Thank you for confirming that the instructions in the article fixed the problem. It is the hot fix for the known performance problem. There is also a BETA FW 6.5.0 available, we are still waiting for the official release.
Thank you for your patience and cooperation! We appreciate your contribution to the community.
