Adz
Apr 25, 2013Aspirant
New owner readynas 102 help
Ok I'm totally lost and confused, I wonder if some kind soul would answer a few questions? How on earth do I install transmission on it and add files to download? I copied a couple of movies on th...
OOM-9
Apr 25, 2013NETGEAR Expert
Adz wrote: How on earth do I install transmission on it and add files to download?
The Transmission App is available from the App section from the RN102 admin interface.
If you have not been to this page, it will take a few minutes to install the tools needed to get access to the available Apps.
Adz wrote: I copied a couple of movies on there in the video folder, but it doesn't seem to display Mkv files on my ps3?
I have the same issue with my PS3, but I found that it was the limitation of the PS3 supported media.
Adz wrote: I only bought 1x3tb drive as my funds ran out, if I buy another one can I just slot it in and will it be a mirror of the first?
If you keep it in XRAID (or RAID1), you can add the new drive (same size or larger) and it will mirror over to the new disk.
