Adz
Apr 25, 2013Aspirant
New owner readynas 102 help
Ok I'm totally lost and confused, I wonder if some kind soul would answer a few questions? How on earth do I install transmission on it and add files to download? I copied a couple of movies on th...
Darth_Vader
Apr 25, 2013NETGEAR Employee Retired
Adz wrote: How on earth do I install transmission on it and add files to download?
Please refer to viewtopic.php?f=36&t=70679 and viewtopic.php?f=36&t=70688#p392513.
I copied a couple of movies on there in the video folder, but it doesn't seem to display Mkv files on my ps3?
You have to turn on ReadyDLNA from System > Settings > Services.
I only bought 1x3tb drive as my funds ran out, if I buy another one can I just slot it in and will it be a mirror of the first?
Yes, now you're in unprotected mode, so getting another one will make it redundant (protected).
Thanks
