Adz
Apr 25, 2013Aspirant
New owner readynas 102 help
Ok I'm totally lost and confused, I wonder if some kind soul would answer a few questions? How on earth do I install transmission on it and add files to download? I copied a couple of movies on th...
Darth_Vader
Apr 25, 2013NETGEAR Employee Retired
StephenB wrote: It's NOT in the app store for RN1xx, so don't go crazy if you've set up genie and it doesn't show up.
Darth Vader wrote:
Adz wrote: How on earth do I install transmission on it and add files to download?
Please refer to viewtopic.php?f=36&t=70679 and viewtopic.php?f=36&t=70688#p392513.
As posted above, it can be manually installed.
transmission is only available for 312/314/316 x86-based box at this time. The arm-based version will be posted soon.
