chicknchock
Sep 08, 2012Aspirant
NEWB 2TB + 1TB....? what will happen>?
I have just put one 2TB drive into my NV+2 and its working great, i have realized i have another 1TB sitting about doing nothing and also 2 x 500GB's what would happen if i was to put these into the ...
Sep 08, 2012Guru - Experienced User
Drives fail. If you assume a 4 drive array, you will have about 1 disk failure per year (since consumer drives typically last 3-5 years).
chicknchock wrote: sorry im new to all this as you can see,
assuming i did that it would be
1) Drive one = 2tb of data
2) Mirror of 1)
3) 2tb expansion
4) 2tb expansion
im failing to see what the point of mirroring drive one would be, assuming i did this would i end up with one 6TB drive in my network and not 3x2TB?
i have tried reading the manual but i can't make sense of the logic. thank you again for your awnser
With XRAID-2, you are getting single-drive redundancy. This protects your data even if one drive fails.
If two drives fail (which does happen btw) you would lose your data - so keeping up to date backups is still important. However, rebuilding the NAS from backups is a time-consuming process when you have lots of data - several days at least. So the RAID protection is still is an important benefit.
Plus, the redundancy is what makes it possible to upgrade a smaller drive with a larger one.
