timothy_J_O
Mar 12, 2013Aspirant
Newbie needs some help
Dear all,
I was wondering if someone could offer me some help?
I’ve been asked to look at a friend’s Netgear ReadyNAS box (Model: rndp2210) to see if I can figure out what is wrong with it. The box doesn’t seem to boot up at all. When you press the power button, the fans kick in and the power button lights blue, then the “act” light flashes green a few times and the unit just sits there. The disk activity lights do not come on and when I load the Raidar software it doesn’t find the unit.
After reading the manual I booted it up in the “boot mode”. This seems to work fine but it doesn’t do anything. I have tried to reload the OS and do a factory reset.
When I try to do a factory reset the following happens:
Booted into the “Boot Menu” by holding down the reset button
Pressed the backup button so just the disk 1 LED was lit.
Pressed the reset button again to confirm the factory reset.
All the unit does is power down, comes back on and just sits there with the fans running (no lights at all) Is this correct?
I have tried to boot the device with out any disks inserts/with new replacement disks and it does exactly the same so I think the disks are ok.
Could anyone offer any advice?
Many thanks
Many thanks
support.netgear.com is what he should use. Phone support would not be free.timothy_J_O wrote: Excellent, I’ll let him know and arrange a support call.
Just out of interest, is there anyway of rescuing the data?
